Mazda Engine General \  bypass hose
bypass hose
views 605
replies 8
following 5
effdbmx1   +1y
i was looking online and i read that a lot of cars dont need bypass hoses cuz the water just flows through the radiator. would i b able to block mine off? cuz from what i understand, it lets coolant flow through the engine wiithout going through the radiator. and this is only before it gets warm. am i right, or is there something really big that i'm not getting?
toddluck   +1y
just fix it right man and save your self problems down the road
effdbmx1   +1y
ya i would but, if you read some of my other posts, the metal tube sticking out of the engine that the hose goes on broke. and to change that peice, i need to take of a whole lot of stuff, including the timing belt. i'm not scared to take most the stuff off but i dont want to touch the timing belt. and i'm not going to a mechanic cuz its a minimum of 200 and i just dont trust them. and my dad has the ability, tools, and place to do it but he's in LA and i was planning on driving down there this weekend.
the peice is glued on pretty good for now. if the bypass hose isn't a high pressure hose then i'll be fine. and i'm pretty sure its not high pressure
dropped90(justin)   +1y
timing is fine to do. just put it to top dead center pull the belt off and slip it right back on the way it was.
-justin
effdbmx1   +1y
idk i'm still not sure about it and i dont want to try it for the first time on my own. is the bypass hose pressurized or does it get blocked off once the engine warms up?
honestly man i couldnt tell you. try talking to hoc or pont or nytrdr.
-justin
Cusser   +1y
I sent you a private message.
1dayiwill   +1y
post a pic of what the bypass hose is. im trying to change the water pump and it is stuck due to what I believe is the bypass hose. is this it? would anybody know how to get it off the water pump?
effdbmx1   +1y
go to my other post, "f*cking engine". i have a pic there of me pulling it off. its right next to the thermostat. but i think that the water pump is near or under the timing belt cover. the bypass hose is a small (7 or 8 inch) J shaped hose.
