Page 1 of 3
Mazda Engine General \  what is the difference B2200 and B2000 motors
views 3299
replies 20
following 10
chris   +1y
i was woundering becouse i have a B2000 i drive and i have a B2200 for parts and i want to rebuild the B2200 motor and put it in the B2000 was woundering what i will have to change i was told the only thing that was different in the motors was the bore size thanks for any info
dropped90(justin)   +1y
you can put the 2200 in with no problems. only thing different is the bore size and stroke, and different cam and valve train.
-justin
chris   +1y
ok i was just woundering so the block is the same
roger26i   +1y
great combo on 2000 motor is the 2200 crank and rods /2.0 pistons and 2.2head for more torque or 2.2 block with 2.0 crank and rods with 2.2 pistons and 2.0 head for higher revs
pont   +1y
Its not 100% the same but it will bolt right in place of the 2.0 that you have. I say this cause I don't wont you getting parts for the 2.0 while trying to rebuild the 2.2. Use the 2.2 short block and your 2.0 head and solid lifters.
mazdamn   +1y
2.0 head is SUPERIOR. Adjustable rockers. Must have with larger lift cams.
chris   +1y
so the 2.0 is is solid and tghe 2.2 is hyd well useing the 2.0 head on the 2.2 up the compression
chris   +1y
sorry i mean is the 2.2 solid
pont   +1y
No the head casting is the same. Just the rockers are different. If you take a 2.2 block and put the 2.0 head on it. It will be the same as a stock 2.2. Just with solid lifters instead of hyd ones which suck.
toddluck   +1y
werd
