Mazda Engine General \  How do you remove the timing sprocket?
views 607
replies 7
quadmasta   +1y
The one the crank pulley bolts to? There's not enough room between the little ridge cast into the block and the sprocket itself to get a gear puller in there.
When I get it off, how do I get it back on?
pont   +1y
I used a steering wheel puller to get mine off.
quadmasta   +1y
How'd you put it back on?
Steering wheel puller is a good idea.
lofosho86   +1y
yeah steering wheel puller works good!did mine the same way!to put it back on i just lined it up and tapped it back on with a deadblow hammer(hit it easy)and tightened it back up!!
dropped90(justin)   +1y
nothing like a BFH (big f**kin hammer) very multi-purpose tool.
-justin
quadmasta   +1y
So there's supposed to be a bolt in the crank? I thought so.
Stupid previous owner. There's SO many bolts missing from this truck/engine it's not funny.
Spun bearing in #3. The top ring in 1, 2 & 4 fell apart when I pushed the pistons out.
pont   +1y
There is supposed to be a 21mm bolt on the end of the crank and 6 10mm bolts that hold the belt pulley to the timing pulley
quadmasta   +1y
The pulley bolts were there, just no huge bolt in the middle of the crank.
