Mazda Engine General \  bad oil leak??
bad oil leak??
views 1898
replies 6
allupinu69   +1y
I have a real bad oil leak on my 87 b2000. Its leaking from the front lower area, oil pump?? Ive heard of the crank seal and cam seal possible leak, but the leak is pretty bad. Any help, thoughts hit me up =].
nonamedsomebody   +1y
I had an oil leak up front turned out to be the crank seal I had the cam, crank seal and timing belt replaced when i got mine replaced
mazdatweaker   +1y
post deleted
Post was last edited on May 12, 2009 02:05. This post has been edited 1 times.
allupinu69   +1y
yah i have the timing cover off the crank pulleys still on. It looks like theres oil leaking on the lower area crank, oil pump area. Ill take pics tomorrow.
toddluck   +1y
its your crank seal
allupinu69   +1y
dam im hella laggin it on this lol, so wat are the procedures to replace both seals cam and crank? might as well replace cam seal to while i am at it right? I got the timing belt cover off, ive never messed wit taking off timing belt. The crank pulley is bolted with bout 6 bolts i think and should come off right?
allupinu69   +1y
ok guys well i took it apart and the leak is lookin like the dam oil pump is leaking. This bad boy is going on 300 runs good dont smoke but if i need to change the oil pump is it worth it?? Or jus start lookin for an engine lol
