Mazda Engine General \  lifter ticking?
lifter ticking?
views 581
replies 4
mazm   +1y
i had my motor rebuilt back in the summer its ran fine till now i changed my oil sunday and the past 2 days its started ticking and it doesnt stop even when warmed up i put 10w 30 valvoline in it with a tough guard fram filter, how do i fix this? how do i adjust lifters if thats what it needs? help as asap thanks
quadmasta   +1y
Overhead cam engines don't have lifters. You need to adjust valve lash.
maztang (ryan)   +1y
^^^what?
if it is a 2.2 then they are self adjusting and you have to find which lifter it is and replace it. if it is a 2.0 then you adjust them. personally, if it is a 2.2 i would get a 2.0 head and use the rocker assy. much better!
mazm   +1y
yeah its a 2.2 are they hard to swap out or anything i need to look out for? any pointers?
maztang (ryan)   +1y
pretty straight forward really. nothin really to look for. just make sure you adjust your lifters after you install them and then crank it up and get it to operating temp and then adjust them again. here is a link to a how-to that dropped90 did. and you don't have to pull the head off to do the swap.
