Mazda Engine General \  302 mounts???
302 mounts???
views 842
replies 5
following 6
weeman   +1y
Dose anyone out there sell a kit I can Buy. I need to get this swap done in a weekend!! help me please!!!
audioinmotioninc   +1y
if you get it done in a weekend... please do a write up... that way i can get my 302 swap done in a weekend as well........lol
elbine69   +1y
Not anymore. v8mazda4ever sells mounts but there for 350's I believe.
racer x   +1y
Any mod like that on these trucks is a custom mounted deal.You'll need to mount the drivetrain and then figure out what to do with the driveshaft as well.If the 302 is carbed it'll make things easier as well.
2slow5.0   +1y
heres how i did mine. the first time (ive got solid mounts now) this retains your stock mounts as well....
there are two styles that i have seen on ford car engine mounts, my first mount was out of a 88 mustang gt. this was very simple, just make the bottom most hole larger. mustangs use similar mount like our mazdas.
the second ive used involves using a mount bracket that uses a long horizontal bolt to hold the motor in place. locate the 302 in the engine bay of your truck. lower the motor till you get to the right position. then all you do is weld a plate with an angle to it that will mount the motor to you stock mount
i understand that my not make much sense but i can go into more detail iff necessary
v8mazda4ever   +1y
the big thing it will take more than a weekend to do it as there is alot of small things that pop up. pm me your number bro and I can help you with some of the engine and tranny mounts and some other details.
