Mazda Engine General \  Oxygen sensor with Weber carb
views 1314
replies 13
following 8
prwmetalman   +1y
Do I need the O2 sensor with the Weber conversion?
quadmasta   +1y
You don't need the engine computer, which is the only thing that reads the O2 sensor, so no.
elbine69   +1y
Nope not needed.
dropped90(justin)   +1y
delete it along with all the other computer shit
-justin
prwmetalman   +1y
thanks for the info.
i hope to set the engine in this weekend i guess.
some pics of my engine
hex0rz   +1y
You could get an air/fuel gauge and use the 02 sensor to make sure your carb has the right jets...
chris   +1y
ok i have a qustion i just ordered my weber do i need a fule reg
prwmetalman   +1y
my '89 2200 has an electric fuel pump that is putting out 7.5 psi and the Weber calls for 3.5 so I went to the autoparts store and bought a Mr.Gasket fuel pressure regulator that is adjustable from 1.5 to 6 psi for about $20. I also read on this forum that some are running only 2 psi on the Weber to get the best performance.
toddluck   +1y
we will require more pics of the truck as well..lol
i run 2.5 psi on my weber. if you cram the gas i have a slight hesitation and then it pics up quickly after. i have some more tuning to do i believe.
-justin
