Mazda Engine General \  alternater questions
views 464
replies 7
3rdtimesacharm   +1y
between the air compreser and my sterio when i stop my truck sounds like it wants to die. when i turn every thing off it runs fine. i m going to get the alternater beefed up but how much can i go? or shoud i just buy a bigger one?
90-b22dawg [andrew]   +1y
do a alt swap.... gm 1 wire.... or 95 mustang 130amp....
slammedyota91   +1y
Buy a bigger one, Stock is onlyy 55amp, its a pos, GM alternators are cheap and a simple upgrade..
3rdtimesacharm   +1y
do i need to make new brackets or do they just bolt up?
audioinmotioninc   +1y
95 cobra alternator bolt up with a little fab.... (adding a 3/8" spacer to the engine side of the adjustment bracket and rewiring 3 wires) other than that it is cake.... it will set you back between 150-200 depending where you go but it is really simple... i just went thru this hassle last weekend so check out my tech article on it and make your own decision..... i chose the 130 amp alternator due to the fact i am currently running 2 viair 380's and will be running 6 total with 3 amps along with either 4 optima yellow tops or 4 kinetik batteries to back up the alt.....so if you run 2 comps and 2 or more amps the 130amp will be the best best and more than likely it is in stock at your local parts house....
moved the pics over to my own post......
Post was last edited on Mar 01, 2008 03:03. This post has been edited 1 times.
oops... didnt mean to jack the post........my bad... i will move this over to my post " 22" wheels..."
3rdtimesacharm   +1y
thats cool bad ass truck pics!!!!!!
