Mazda Engine General \  Secondary Exhaust
Secondary Exhaust
views 542
replies 5
hexhead   +1y
Will my truck run with out the secondary exhaust pipe from the top of the manifold to the air intake/carb? Of course i would have to fill the holes on the manifold so i dont lose back pressure.
elbine69   +1y
Yes.
hexhead   +1y
Would it run the same? Would it warm up slower. Also do i plug the hole that is going to the intake/carb?
shilaeli huggr (burdaddy)   +1y
if your talkin bout what i'm thinkin ur talkin bout its just a heat riser and takes heat off the manifold and into the intake.
i took mine off then cut away that metal cover. the hose isn't attached to the manifold, just the cover.
dropped90(justin)   +1y
your talking about the smog pipes. yes it will run fine, just cap off the holes.
-justin
hexhead   +1y
Thanks
