Truck Died
Truck Died
mxer201
While driving home the motor in my B2600i decided to die on me. No warnings or anything. Right after it died I believe all the idiot lights came on including the HOLD light. I thought it was odd the HOLD light coming on. Once stopped I tried to start it and it seemed like it would try to run for a second but no. Haven't been able to work on it yet but the first thing I'm going to check are fuel delivery and ignition spark. Computer was repaired by AVproecm back in 2004 so hopefully it is ok. Any suggestions before I get started on it?
badchicn (rick)'s avatar
badchicn (rick)
Wow, the same thing happened to me and it was the computer.
mazdatweaker
post deleted
Post was last edited on May 13, 2009 06:56. Edited 1 time.
elbine69's avatar
elbine69
Check the crank position sensor. Mine went bad and did the same thing
mxer201
Got er done!! Problem was the ignition coil. No spark at all. I replaced the original coil with this one from O'Reily back in 2006. Good thing about the O'Reily part is that it has a limited lifetime warranty. I'm glad I saved the old coil. Once the old coil was installed the motor started instantly!
kia swap
last post by Brody +1y
51
