Mazda Engine General \  I need help guys!
I need help guys!
views 529
replies 5
bagged_87   +1y
Ok, so the mazda has recently had some miles put on it and like an idiot i left the compressor on with the truck of which of course killed my battery. Since then its been driven once via being jumped off, but today when i tried to drive it again by jumping off, i drove a little and every thing died! Completely as in no lights, no airbags, no compressor nothin! Im baffled! Im thinkin it just that the battery is is completely dead to the point of no return...id realy liked you guys help on this one....please...
Thanx in advanced guys.....peace
audioinmotioninc   +1y
only thing i can tell you is try to jump it off again...
once it is running.... check the voltage at the battery.. it should be between 13.0-14.5 volts..... if it is in that area... disconnect the positive terminal on the battery... the truck should stay running..... if it dies then it is your alternator. also i would check the voltage of your battery with the truck off as well... it should be around 12 volts..... after you find out those answers check back and let me know.
bagged_87   +1y
Alright cool thanx....
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 06:05. This post has been edited 1 times.
bagged_87   +1y
Thats what i was thinking Mazda tweaker thanx for the info, any new info is always good info....Get with you guys tomorrow on what the deal is..
toddluck   +1y
your battery is fried
