Mazda Engine General \  Aftermarket cams and head porting
views 1116
replies 12
baker   +1y
Is there any sort of race or aftermarket grind cams for the mazda 2 litre? Also anybody ever do any head work to there motor and what kind of power gains were there? I wanna see what I can do with a mazda motor. Thanks
hocbj23   +1y
Paeco in Birmingham will grind any kind of cam u want or need from mild to wild.Polishing and porting heads increases air flow or volumetric efficiency which leads to better performance.Unless u did before and after dyno pulls it would be difficult to quantify.My 2200 went from 85 hp to 122 hp with a change to a Weber carb,better ignition,Paeco street cam,stiffer valve springs,solid lifters,electric fan,aluminum crank pulley,and a ported and polished head-also gasket matched.Hope this helps.
baker   +1y
Thanks that defientely help. I was just looking into getting an E fan for it so I can get rid of that noisy fan clutch. What fan are you running?? and is it a "push" or "pull" style fan.
hocbj23   +1y
flex-a-lite 13 inch pull type with an adjustable thermostat.bj
nytrdr24   +1y
before you spend the dough on someone doing a port & polish, you could look @ getting it extrude honed....you'll spend about the same for a port/polish, but the runners will flow the exact same cfm, whereas if someone does it by hand, you may flow a little more in one than another...
I had mine done, it ran @ $600 to get it done, but the runners look like mirrors!
hocbj23   +1y
where u been NYTRDR?BJ
nytrdr24   +1y
Workin like a dawg man, started my outage at work, it'll be may before I get a chance to breath.....
baker   +1y
Sweet thanks guys that pretty much wat I wanted to know. Ive been looking into shops that do head work with no avail. most shops around here just rebuild heads.
hocbj23   +1y
dont get too busy and forget ur homework.Lol.BJ
nytrdr24   +1y
got that taken care of.....big day set for may 17th....
