Mazda Engine General \  harmonic balancer
harmonic balancer
views 742
replies 8
ja2000   +1y
i have been trying for two weeks and broke three pullers is there a certain way to take that geared pully for the harmonic balancer off??
toddluck   +1y
no clue if your breaking pullers something is very wrong....might have to take her in to get it pulled
quadmasta   +1y
Take the pulley off by removing 6 10mm bolts. Take the crank bolt out. 21mm. You'll probably have to heat it with the torch. Rent a harmonic balancer pulley from Auto Zone and go to Ace and get longer bolts that'll thread into the timing pulley. Heat the pulley/crank and use the balancer to pull it. It should come right off.
ja2000   +1y
why would i need to remove the crank bolt the pully is over it?
quadmasta   +1y
The crank bolt holds the timing pulley that the crank pulley is bolted to.
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 06:05. This post has been edited 1 times.
ja2000   +1y
i wasn't asking in a rude way i was asking for my own education i will give it a try thanks guys.
ja2000   +1y
bump.... is the bolt reverse thread?
quadmasta   +1y
No. Heat it up. When you think it's hot enough, heat it more.
