So I extended my lines and the plug for the sending unit and relocated my tank yesterday, and now I can't get any gas to the motor... I don't know what details to include, but can anyone help me?
joemazda93
Did you accidentally swap your gas lines?
terrorcck
Im 99.9% sure that I didn't but i guess its a possibility.. Which line from the sending unit goes where? I've looked for a diagram but haven't found anything..
is your tank higher than your fuel pump??
joemazda93
I'm not sure which line goes where. Sorry man, mine's fuel injected.
long roof
Is your pump turning on?
hex0rz
Air bled from the lines? Takes a while for the pump to get fuel again, take the line off the pump and siphon on it until the air is gone and the fuel comes out.
terrorcck
I have a newer fuel injected motor in my 88..
terrorcck
Tank is in the front of my bed also
roger26i
do you have the polarity correct for your pump wires +to+ -to- if they are backwards it will burn your pump up
