Mazda Engine General \  Engine tempeture sensor for gauge...
views 701
replies 9
following 5
f n lo   +1y
alright guys heres my issue, i have put a whole new motor with a weber carb in, everything runs perfect, however i cant get a tempeture reading on the gauges. there is aplug in the bottom of the rad that i wired up how it was before the swap and still nothingnow i saw a plug with a wire in the bottom of the thermostat housing, but it seemd to be pluged...
I need the tempture gauge to set my elec. cooling fan... it also has a pacesetter if that changes anything...
Thanks in advanmce for any help!!! im in a pickle herre......
pont   +1y
the one that runs the gauge is on the thermostat housing so check the wire make sure it is not cut. the sensor might be bad as well
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 05:05. This post has been edited 1 times.
toddluck   +1y
ground the wire under the stat housing and see if your guage goes all the way to hot if so its a bad sending unit
f n lo   +1y
alright souynds good, now can anyone show me a pic of where in the harnes is goes? i pull my left side harness completly out, and i have no idea where the wire connects to the harnes which then goes to the gauge... thanx again guys...
f n lo   +1y
any body??? i was hoping to hook his up his weekend.......
dropped90(justin)   +1y
ill look on mine and see if i can find where it goes for you. what is the sensor in the bottom of the radiator for?
-justin
f n lo   +1y
id appreciate it bro, is it the same harness as the alternator and starter? im thinking maybe the plug in the bottom of trhe rad is for the computor?? just a wild geuss,
Thanx for the help....
f n lo   +1y
FOUND IT!! hahaha mystery solved, i was looking through my manuel and fount the wiring diagram and found out the wire is yellow with white, so i split open the harnes by the alternator and tested it and i got lucky( or was it skill, u decide, hahaha)
Thanks for the help guys, i got pics up of it in the rides section...
toddluck   +1y
glad yuo got it fixed
