Mazda Engine General \  Engine... idk...
Engine... idk...
views 520
replies 4
following 5
gavin_mosher   +1y
okay... heres the problem as i accelerate it has great power its just once i get going it starts stuttering.... idk how to explain it it like pulsates. anyone have any ideas what may be up?
daddysparks   +1y
have you checked plugs ,wires, cap ,rotor bug and coil? then check cat convertor check all vac lines....
88b22   +1y
my my truck did the same thing i believe yours is doin...it runs great acelerating up to speed then when you level off at 65 or whatever it cruises intermittently...it will stutter then it will cruise normally then stutter then cruise normally again right?...i found a vaccum line that wasn't hooked up and another that had crack in it...i fixed them both and fixed my problem...you should also check your fuel filter while your at it...
dropped90(justin)   +1y
mine was doing it and turns out it wasnt gettin fuel.
-justin
toddluck   +1y
also might wanna check you vacume advance
