22k engine question
inspecterbear@aim.com's avatar
22k engine question
h8hytz's avatar
h8hytz
ok so i tried a few things to try and solve my engine problem finally was told that it was a bad carb. i scored one for free but 3 hoses from mine doesnt match the other one. my biggest question is when i unhooked the three hoses on the front of the air cleaner box i guess the reed valves? alot of creamy colored sut came out.would issues with this cause problems for the engine??? ran a lot better (at higher rpms) than with the air box hooked up. any ideas????
check for blockage
h8hytz's avatar
h8hytz
well im sure there is a blockage in the little box that is connected to the air box. i guess my big question is that i was haveing problems with the engine (havent drivin it yet will l8r) but when i disconnected the air box and all the lines to it the truck ran alot better at idle than it has since i had discovered the problem. with just the stock carb can i leave it like that?? and how hard is it to go with a holley 5200 (little bit cheaper for me) thanx again guys
if you go with the holly you can ditch all that hose crap and you ecu
h8hytz's avatar
h8hytz
thats good. and do u reckon that the blockage was causeing black smoke and poor idel? like i said i will drive it this afternoon to see what it does under driving conditions w/o the air box and what not connected and hopefully has corrected the problem(please excuse me im all sinused out going to the docs in a bit)thanx again
