A/C Question?
A/C Question?
kezʹs-89
Does anybody know of another a/c compressor thats a bolt in for the B2200? Like out of an RX-7 or MX6, and so on. My compressor is locked up and its hot as hell in florida allready, Fat guy needs his A/C any help would be much appreciated!
hocbj23
Have u checked it to be sure it doesnt just need Freon? Also the old units can be converted to run R134 pretty cheap.Doesnt cool as fast but it does work and saves paying out the wazoo for the old stuff if u can find it.BJ
Cusser's avatar
Cusser
He said his compressor was locked up (middle part won't turn, even by hand), so it's not a refrigerant level issue. I wouldn't go the used route at all on these, not worth it considering that you'll be needing a new drier, evacuation, and recharge no matter what. And you guys in Florida don't know hot, I'm in Arizona. And the two leading suppliers of AC stuff on the Internet are here as well. They both say the only rebuilt compressor to buy is the one from Air Pro, and that's what I have in mine. And I'd keep it R-12, still available, works better than R134a in systems designed for R-12, and more importantly R-12 is compatible with the refrigeration oil already in your system. You may also want to solvent flush the condenser (backward from the dier connection) in case there's debris in there from the bad compressor. I'd contact Warren at .
kezʹs-89
Thanks for your help Cusser! I'll keep that on file. I was just lookn for a cheap temp. fix for the problem.
Cusser's avatar
Cusser
Unfortunately, there are no cheap quick fixes for AC systems. Do it right, and do it once.
kezʹs-89
This I know, But the local pull-n-pay has an ass load of mazdas and i can get a compressor for $20.00 Thats cheap But would be temporary, till funds are alittle better.
supratreo
try picking the compressor you need then click the link above the pic. and it will show you what other cars that part fits. hope that helps.
kezʹs-89
thanks man that should do it!
kia swap
last post by Brody 12 mo
51
