Mazda Engine General \  automatic transmission questions
views 520
replies 5
cl (chris)   +1y
Will a automatic transmission bolt right up to 2.0? will it bolt to factory 5 speed transmission cross member? Will a automatic fit in the stock 5 speed location thru the floor?
flameds10(tyler)   +1y
ok, it bolts right up to the motor, u will need to get the auto motor to tranny mounts that are on the lower parts of the motor, they are different then the manual ones, also u will need to ream out the fly wheels center hole so the converter slids in i think.... as for the manual cross member u do not use it, u will need the tranny mount and iy mounts to the cross member right behind the manual one, u will also need the auto driveshaft cause its different
i can go out and take detailled pics if u need them
also if you have a pacesetter header you will need to trim the tranny for it to clear
toddluck   +1y
and i have all those parts cl...except no flywheel or converter
cl (chris)   +1y
Todd i should be able to roll up there in the next few weeks i have t o fly down to southern CA you mentioned you had a motor as well
