transmission
transmission
AD
at dusk
ok guys.. so this truck is pissin me off o bad.. it wanted a new engine i gave it a new engine.. but now the transmission doesnt work at all.. it worked with the other engine.. but not this one.. same engine urrg.. ok so the clutch is in the engine running put the truck in gear.. let the clutch out.. nothing happends.. i know with my ranger when i was low on tranny fluid the truck wouldnt go into reverse.. could that be the issue ..?
hex0rz
Did you remember to put the throwout bearing back in? Did you drain the gear lube from the tranny?
Tell us the facts...
AD
at dusk
found the issue.. slave cylinder had to be re adjusted and she works fine now.. the truck was acting like the clutch was always pressed in
kia swap
last post by Brody +1y
51
