Mazda Engine General \  weber carb ?
weber carb ?
views 599
replies 3
mazdabon2nd   +1y
i have a wber carb and i want to do a turbo set up. i was going to do a mx6 swap but i cant find a wire harness for it so i gve up on that, so now i want to just turbo my b2000 motor. i heard that i have to make my carb a blow through. my question is how do i do that?
90-b22dawg [andrew]   +1y
man you should do the mx6 swap you'd be alot more happier with it imo.... and without building your motor you will risk breaking shit with a turbo...
mazdabon2nd   +1y
if you or anyone can find a mx6 turbo,5 speed harness for me i will do it. but in ny there are none that i can find.
hocbj23   +1y
basically if u have seen a couple of monster four barrel carbs sitting on top of an equally monster blower -then reverse the position of the carbs and blower u will have a "blow-thru arrangement."The s/c or turbo blows the air thru the carb,not the carb sucking air/fuel thru via manifold pressure. The easiest way to do it is supercharge and not turbo,because u r spinning the turbo up with hot exhaust gas and hot exhaust gas and atomized fuel somrtimes make things go "boom".Lol.Big trick would be to get someone to fabricate a bonnet to enclose ur carb so u could pack in as much air as possible.See if u can find an engine pic of a 1957 Ford 'Bird with the 312 supercharged engine and u will get a better idea.Can be done but u r talking some major fab work plus working with air /fuel mixtures and intake manifold pressures until ur head spins.Good luck.BJ
