clutch problem
clutch problem
amgine_
so the other day i down shifted to 3rd and was hard to go in gear but forced it in..after that my clutch pedal came really soft and couldnt go into any gear... changed the slave and started bleeding.. pumping the pedal for about an hour still no pressure build up.. so went back to napa and the guy guy told me i had to do it in reverse.bleeding from the slave up .. pressure came back and goes into gear but with force.. sometimes wont even go in gear it would just sound like the plates are rubbing... time for a new clutch??
91b2200(cody)'s avatar
91b2200(cody)
prolly a new clutch maybe ... mine did sumthing similar and i replaced mine to and no probs. but not sure
sounds like you may have broken your pressure plate
amgine_
alright thanks guys
kia swap
last post by Brody 12 mo
51
