Mazda Engine General \  White Smoke???? Help
views 558
replies 8
following 6
amgine_   +1y
jus changed head, water pump, fuel pump, flowmasters, put in 3236 n pacesetters 77 miles in... noticed when at idle no smoke. rev alittle some what light dark smoke but a slight full throttle alot of white smoke comes out.. unburnt fuel? shaved head? headers??
trplezro   +1y
White smoke is usually always in relation to oil burning.
Pull the plugs out to see if they have oil on em.
layedoutb2k (chase)   +1y
blue smoke is reletive to oil burning
white smoke is reletive to coolant burning
did the head get torqued down right?
ayreshead79   +1y
or did you get the gasket lined up right... if so try some black RTV and put a new head gasket.. put a lil RTV on both sides of the gasket.... not too much just enough to seal it.....
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 04:05. This post has been edited 1 times.
low down89   +1y
its also a good idea to retourqe the head after letting the engine idle till it reaches normal operating temp
amgine_   +1y
thanks. it was a machine shopped 87 head onto a 93 block installed gasket dry n torqed right.new fuel pump.. oh yah fogot to mention new radiator... would that have to do with it blowin smoke.. would everything being pretty much new have to do with it.. i asked a friend n said that everything was new thats why it smokes like that n it would eventually go away. but i trip out on when i full throttle it smokes alot of white
are you sure it was an 87 head onto a 93? i believe they are completely different motors. 93 was when the mazda became just like the ford ranger, motor and all.
amgine_   +1y
garenT 93
