Mazda Engine General \  no gas to carb
no gas to carb
views 678
replies 11
following 5
cnsparx   +1y
i am not a mechanic at all. i have replaced the fuel pump and filter and i am still not getting gas to the carb?????any ideas????i have also used carb cleaner and it will run if i pour gas direct to the carb????
toddluck   +1y
you might have an obstruction in your tank pull the tanks and make sure there is no crap in it
bulrid8   +1y
Take your fuel line from the tank and blow air thru it, back to the tank. This will help clear it out.
90-b22dawg [andrew]   +1y
if there is junk in the tank (more then likely rust from the years) you will need to drop the tank and flush it out....
cnsparx   +1y
will air in a can be strong enough cuz i dont have a compressor here???haha not kidding
cnsparx   +1y
is there a product i can dump in there???? seafoam or lucas? The bed is off so access to the tank is really easy.
toddluck   +1y
if you blow air back through the system you will blow off the sock filter and will only have more problems in the futur pulling the tank is easy
cnsparx   +1y
so u suggest just to drain the tank and refill?
toddluck   +1y
no drop the whole tank so you can remove the sending unit and look inside your tank to see whats all in there
cnsparx   +1y
not to sound like a retard but i took out the sending unit and glanced insied a week ago and saw gas but i ididnt look too hard, what should i be looking for?
