Mazda Engine General \  help needed!!
help needed!!
views 504
replies 6
bodied b2600zx (josh)   +1y
I have a 93 b2600 and i replaced the trans.... i havent driven the truck since i bought it and i did alot of motor work..... anyways, i finally got it started and i focused on finishin the trans. I got the trans back on and now it won't start....
My question: One of the bolts that bolts the starter and trans on had ground wires on it.... I thought it had more than one... now i put it back on and could only find one ground, the one from the battery..... Is there more grounds than jus that one??? And if so, do you know what they're for so maybe it'll help me find em.. THANKS!!!!!!
90-b22dawg [andrew]   +1y
should be just one ground... and of course a power wire and a ignition switch wire.... the smaller of the two on the starter.... do you have a multimeter? if so check the voltage of the smaller wire with the key on.... if no juice on that wire then you'll need to either run a new wire for ignition hot or figure out why its not getting hot.... check all the fuses
well it'll turn over jus fine.... I'm gonna put some gas in tomor, i have no clue how much is in it, its probably jus somethin stupid like that
toddluck   +1y
pour some down the carb and see if it fires
izulowtoo   +1y
shouldnt be a carb, unless hes changed it, it is FI
yep, 2.6 FI
toddluck   +1y
my bad...fuel pump or computer??
