clutch noise
clutch noise
amgine_
just put trans back together without 2 14mm bolts and one 17 bolt... ok for the first day clutch started slipping after each shift.. bled it n everything went ok.. but a day after a squeaking noise started ... to me.... i believe it has somthing to do wit the release bearing..i really dont know... all i know is that when at dead stop or in gear it squeks and comes louder as i gain speed.. but when i presss the clutch pedal just alittile bit. imean about an inch to inch in a half(clutch dosent grab) the squeak stops.. only when i press the pedal lightly... any advice on what it might be and how i can stop it????
you may need to readjust the push rod from the pedal the one that goes into the clutch master itself
kia swap
last post by Brody +1y
51
