Drive Shaft
kingcobra47@juno.com's avatar
Drive Shaft
nonamedsomebody's avatar
nonamedsomebody
My drive shaft has been making a clunking noise when I shift almost like it has a very small bit of slack to pick up before it starts to spin any suggestions.
Mazda b2200 91 ext cab
1smoothdawg
that would most likley be a universal joint
thebeaumartin's avatar
thebeaumartin
does it pop going slow?
thebeaumartin
or while inbetween gears or on take off after stoppin?
climb under your truck yank pull and twist (any questions on that ask beau he has it down pat) on your driveline see if the slop is at the ujoint or the carrier bearing
nonamedsomebody
carrier seems sloppy seems to be the weakest link on these trucks
well you have to figure that bearing prolly hasnt been changed in 20 years ...thats really not to bad
nonamedsomebody
It has quite a bit of play in it now lol. It's due for a swap I have one from my old b2200 that is like new still.
nonamedsomebody
Took the drive shaft out and swapped it with my old one which had a new carrier on it already. The old one was spinning in the rubber boot.
kia swap
last post by Brody +1y
51
