help!!!!!
solowsonoma@aol.com's avatar
help!!!!!
solowsonoma's avatar
solowsonoma
i have 900000 different vaccumm hoses going to wut looks like useless solenoids and sensors lol i have a 87 b2200 with a carb setup and i just wanna no wut i can do to get rid of em which ones do i actually need which ones are just useless emissions junk and which make it run good i wud love to rip it all off and throw it in the garbage lol ne help wud be grreat thanks anthony
sleepyspeed's avatar
sleepyspeed
the best way to remove all of it is to buy a weber carb. then you only need vacuum advance hose. and get a header, or plug the emulsion tubes on factory exhaust manifold.
webers can be found sometimes in the classifieds, or ebay you will also need adapter plate for carb to intake
solowsonoma
does neone no wut there off of or have a part number for carb i work for an autp parts store so i might be able to get one also where to buy the adapter plate
mazdawg(mikey)'s avatar
mazdawg(mikey)
you can cap almost everything on the factory carb but it will run awful. itll run rich and get bad gas mileage.
solowsonoma
yea i dont wanna run shitty or get bad gas mileage i found the kits on ebay they dont seem to bad of a deal r they a pain to do i mean is it just bolt on and go or is there a big deal to change it lemme know thanks guys
sleepyspeed
ford used a solex that was a clone the weber design I used one on a first gen crx that I rallied.
I will see if I can find that part number
adapters can be found on ebay, and years ago when I worked at schucks we could get weber adapters from some performance suppliers
sleepyspeed
there is this one on ebay adapter and all
ford used the clones on some pintos and fiesta not (festiva) if you can look up pics of these at your work just check 70's ford cars for one that looks like 32/36 dgv weber
sleepyspeed
okay dug some more for ya
look for the holley 5200 off of the ford pinto's it was a copied weber 32/36. It can accept the rectangle air filter setup of the weber being it is a licensed clone these can be found pretty cheap at a junk yard and will work good.
like I said earlier ford used it on smaller cars some have emission stuff some don't.
Dodge used them too but not sure what rigs.
kia swap
last post by Brody +1y
51
