Mazda Engine General \  tranny help 2.2 to 2.6 do the interchange
views 582
replies 4
atlc855   +1y
soed the tranny from the 2200 interchange with the tranny from the 2600? need an honest answer asap
elbine69   +1y
negatory ghost rider
atlc855   +1y
can you change the bell housings to have the rest fit?
nytrdr24   +1y
pretty sure that won't work either, the b22k's trannys are type II, and the b26k is a type III, input shafts are 1" instead of 15/16" on the b22k's, and if I'm not mistaken, slightly longer...you might be able to swap the bellhousing, but would also have to swap the tail shaft too from what I have read. There is some real good info on this link, and other links that he has that lead to good information too.
hope that helps ya out some.
xulf13   +1y
yup that's a double negative!! No way...
