Contacts/Points keep burning out
lvnlo
i have to replace my contacts/Points every 4-6 months cause the burn themselves out, They have little burn marks on them> Anyone have the same problem and know how to fix it? I have probably bought about 10 pairs since i've owned my ute
hex0rz
Thats interesting...
I could only think of the fact you are running too hot of a spark? Do you replace the rotor everytime you do the cap?
What do you have for an ign. coil?
mazdatweaker
post deleted
Post was last edited on May 13, 2009 03:42. Edited 1 time.
lvnlo
my ute never had electronic ignition,89 2.0 FE Carby. i replace condensor everytime i change the points, also has an after market coil, but have changed it once before and still the same thing
hex0rz
Sounds like you need to install a ballast resistor as I think you have too hot of a spark. Could be wrong though. Bounce the idea off of some other people first.
huskerdually
Yes you need a resistor on your coil. Or one with a built in resistor.
kia swap
last post by Brody +1y
51
