Hi All -- My 1987 B2000 has an exhaust leak -- After the exhaust manifold there's a short section that goes down, I think there's a cat in there, the first exhaust pipe bolts up to that upper short section. The upper part has three studs, then three nuts that hold it together with a gasket. The studs are rusted and I can't get the nuts tight enough to seal properly. In fact now they are hard to get off.
If I could get in there with a die I could chase the threads and it would seal but there isn't enough room for a die. Any ideas short of taking the whole thing off? Is there such thing as a small die that's the size (diameter) of a long socket? I can't be without the truck right now so trying to avoid the whole manifold removal ordeal. Thanks for your input....
bodied b2600zx (josh)
weld it
dragn37
Wow, tough situation.
hocbj23
if all else fails,I have a 2200 exhaust manifold with downpipe and cat attached.all the way down past the air injection pipes.If u want to replace yours,mine is available..BJ
