Mazda Engine General \  Callin fe3 swap guys! Please help
views 744
replies 9
fe3mazd   +1y
Ok to start i got a 1995 sportage fe3 i got a problem some where in the wiring. I have power to everything it cranks. Wont fire?
fe3mazd   +1y
Ok found out i dont have spark. The coils have power but they arent firing. I know im missing something someone tell me what PLEASE.
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 03:05. This post has been edited 1 times.
fe3mazd   +1y
yeah i got 12v to the coils. And ill try to check for a pulse from the crank sensor.
mazdatweaker   +1y
post deleted
fe3mazd   +1y
Yeah i checked the fuses and the ecm fuse is fine
neptune   +1y
bad ignition control module??
fe3mazd   +1y
What should i b getting for voltage? Im getting 8 to 9 volts
mazdatweaker   +1y
post deleted
matth0le   +1y
I think I might know your problem. Intially mine turned over but did not fire. I scratched my head for a while and finally looked at the Kia schematic again. The ECU needs power into pin 58. I did not hook up power there intially but had it to the coils. I gave that pin 58 power and it fired right up.
