It Whistles when i'm Ideling,And it is LOAD!!! I have pin pointed it to be near the Elec. choke on the Weber Carb. Some where in that area. And it is not my belts! Anyone else come across this?
layedoutb2k (chase)
i have had that happen and it ended out being a vacuum leak. check all of the vacuum fittings on the manifold that they are capped off good. you can spray some starting fluid while its idleing at the fittings. if your motor revs up, it means the vacuum leak is coming from wherever you sprayed.
j-bird
Well the noise goes away when the rpms gets higher the noise goes away. I'm thinking the gaskets between the Weber plates might have a leak. Wouldn't soapy water just do as good, as starting fluid?
no use starting fluid or wd40 cause it burns spray around the base of the carb if it runs different than you found your problem
bulrid8
Use staring fluid. WD40 doesn't work. It use to, when it use propane as a propellant. They change the propellant to non flammable now!
j-bird
Good deal guys. I got some Starting fluid spray today and well work on it tomorrow!
j-bird
question for you guys! When putting on the gaskets for the carb.,What kind of sealent are you using? Also what kind of threadlocker? thank
