Mazda Engine General \  Engine Help
Engine Help
views 373
replies 1
following 2
kirkpenneyfan   +1y
i have a 86 b2000
it has headers to cat to glasspack
it seems to be leaking oil out of the breather hole because i can see oil build up on the filter that i put on their the PCV and PCV hose have been replaced, i have also changed the valve cover gasket twice since i bought the truck and it seems the gromets to hold the valve cover down are not doing the job or the gasket is going bad again because it is leaking oil their too...i also only get a tank of gas for like 3 days is that common and when warm out i get a tank of gas for 7days could that be the way the exhaust is set up or do i have an issue somewhere else?
low down89   +1y
i don't know what to tell you but my fuel economy has gotten worse since winter too could it be the dreaded winter blend fuel or are they diluting the fuel so they can sell it cheap?
