Page 1 of 3
Mazda Engine General \  RX7 / B series trans help needed.
views 1889
replies 20
following 8
mazdatweaker   +1y
post deleted
Post was last edited on May 12, 2009 04:05. This post has been edited 1 times.
matth0le   +1y
Check out this page.
You might get the info you need there.
Matt
dealwithit   +1y
yah i have done the swap and i used a 1st gen rx7 tranny and swapped the bellhousing and tail housing(along with the shifter forks) check out page 11- 14 of my build on mazdatruckin.com
elbine69   +1y
So then the rx-7 transmission can be used with the fe3 also. Good to know
bodied b2600zx (josh)   +1y
Thanks for pointin that out! That is good to know for sure! Cuz I will be doin the fe3 swap in my b2600i. . .
elbine69   +1y
Me too, but with a sweet turbo
Ya thats a big reason why i want to do it too I love turbos
mazdatweaker   +1y
post deleted
matth0le   +1y
An 86 naturally aspirtated tranny should work. Here is a bit more info on RX7 transmissions: .
Matt
mazdatweaker   +1y
post deleted
