Mazda Engine General \  clutch problems
clutch problems
views 741
replies 5
blacktop1981   +1y
I have a problem i pushed in my clutch pedal the other day and it was soft theres no pressure in the pedal at all. I tried bleeding the clutch and there didn't seem to be any air, the cluch has less then 2500 kms on it and slave was replaced just before the clutch was done. The master is original, I'm not losing any fluid and the truck still goes into gear and drives but the truck does'nt move till the pedal is almost all the way out.
Can the master be bad even if its not losing any fluid?
I don't know what it could be, if anyone has any suggestion that would be great.
Thanks and happy new year
hocbj23   +1y
yeah u can get a pinhole in the diaphragm of the clutch and it will leak internally.There is an adjustment on the clutch actuator rod itself under the dash so u might try that first.bj
blacktop1981   +1y
Thanks for the info, if I adjust the actuator rod and it still does'nt help its Probably a good idea to replace the master then right?
hocbj23   +1y
I would.BJ
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 01:05. This post has been edited 1 times.
blacktop1981   +1y
Thanks guys , yea next week all replace it .
