Mazda Engine General \  Lifters 2 type?
Lifters 2 type?
views 419
replies 3
following 2
dirtracer14   +1y
Can someone tell me if the 2.2 has diff lifters for intake and exhaust? I ordered new ones and they came in 2 diff boxes with same part # but 4 are diff than the other 4 . One set is easy to push in and has green o ring the other is very hard with almost no movement and has a orange oring. Putting the head together and dont want to mix them up or if 4 of them are wrong then i need to get the write ones. Thanks, Craig
immortal1 (linn)   +1y
Interesting. Wonder if the O rings are different for a reason and the castings are the same or if you got 2 different parts. I'm sure there is a few on here that know the exact answer you are looking for.
dirtracer14   +1y
I think i got it, one set is pre oiled so they are pumped up the other isnt so they are springy. I pushed the oil out of one that was solid and now it has spring to it. So i oild the other and put them in. I hope it works
I'm sure they will work fine. Probably the intake ones were pre-oiled for some reason. Maybe for better startup? Eitherway, good luck!!
