Need Help Plzz
Need Help Plzz
8
89slammed
ok so i got a 89 b2200 its been running fine then all of a sudden yesterday it started snowing and i was on the interstate and it was running great and then it started surging and i could mash the gas pedal all the way to the floor in 2nd gear and it would never go over 2000 rpms then i got off the exit and it died and when u would try to start it uwould have to mash the gas all the way and it would never go over 1000 rpms it did this to me 3times it has the stock carb so any input would be really helpful thanks guys
F
freaky320
I had a 510 do the same thing. I broke my cam a #1 cyl it would run but would only get up to about a grand then die some crazy shit man. I would run a compresion test an each cly. Might give you a idea where you losing it.check your plugs and wires spray the shit out of the carb with some good claener.may pull the valve cover and make sure its all in place. good luck
jester's avatar
jester
I'm willing to bet that your heat riser tube from your exhaust manifold to your air cleaner is missing. The stock Nikki carbs are famous for icing up especially when the temp is just below the freezing mark outside. When it is doing that pull off the air cleaner lid and look into the carb, you should be able to see a thin layer of ice on everything. It usually will melt if you let it sit and idle for a couple of minutes, but as soon as you drive again it will ice up again
may have jumped time
8
89slammed
i dont think its a compression test cause it would run fine for like 30mins then be right back surging and then die it smells like its flooding and i burned a whole tank of gas in like an hour
hocbj23
Maz's are bad about water condensing in the fuel filter and freezing when it gets cold enough.Run a can of HEET or something similar in tank.Also check heat riser tube as posted above.If it wont get above 2000 revs,something is impeding fuel delivery.bj
8
89slammed
thx guys i checked the heat riser tube and theres not one when i got my truck the stock air cleaner had been removed it has a eldebrock air cleaner on it most of the vaccum lines r plugged too the copper pipe that sit on the Exhaust mani is pinched shut on both sides the truck ran great today i was roasting the pass side tire though 3rd gear so i guess ill see what it does when its cold and would seafoam do the same as heet cause i have surplus cans of seafoam
kia swap
last post by Brody +1y
51
