Mazda Engine General \  clutch kit interchangeability?
views 973
replies 10
following 6
89auto_maz2200   +1y
i need a clutch kit and was wondering if a 84-93 626 clutch kit or any b2000 clutch will bolt on the b2200 without swapping flywheels?
vg30e86   +1y
They interchange just fine Generally are the same part numbers.
91extcab   +1y
will work just fine... just dont try to put a b22/b20 clutch in a b26i. different teeth count... clutch plate from a turboII will fit a b26i, its just slightly smaller in overall diameter than a stock b26i plate.
89auto_maz2200   +1y
big thanks guys.
91extcab   +1y
i think if you really wanted to you could even do the 626 motor swap and still be able to bolt it to your b series tranny... not 100% on that, but im pretty sure ive heard of it being easily done...
gimpy   +1y
I put a F2t in(Probe,MX6 GT),am using a stock 2200 clutch,flywheel,any Normally Asperated MX6 clutch will fit in a B2200 bellhousing,turbo engines had a larger flywheel & clutch,won't fit in the bell ,and you can't put a starter on it without machine work .
Gimpy
89auto_maz2200   +1y
allright didnt know that,my options opene up even more.thanks.
89auto_maz2200   +1y
allright im ready to buy the clutch this is the ones it fits, 323 GT Turbo 88-89 ,Pickup B2000 86-87,the guy said it wont fit the b2200 but you guys say so,buy it or not?
89auto_maz2200   +1y
bump last thing i nee to swap and price is just right.
futrao   +1y
i say buy it the one i got on my truck is a act etage 3 racing clutch for a 88-93 323 gt, 88-92 mx6 non-turbo and 88-92 prove non-turbo and it work beattifully no slip and grabby and it was a direct bolt on.
