Page 1 of 3
Mazda Engine General \  motor problems
motor problems
views 1126
replies 25
following 7
blake_benoit2600i   +1y
i have a 1991 2600i that im havin problems with... it starts up kinda rough but once it warms up it runs ok but when warm and i kill it it wont start up! any help would be great thanks i got the injectors changed a few weeks back also if that would help anyone!!!thanks
anyone???
elbine69   +1y
So it started doing that after you changed the injectors? Or you had the injectors replaced to try and fix it?
it started doin that before i got the injectors changed...sumone told me it was my injectors so i got em changed but it didnt fix the problem i guess you could say both
elbine69   +1y
Changed the fuel filter? Could be clogged. Also check your ecm, they are notorious for the capacitors leaking onto the circuit board and making the truck run weird.
ima look into that ....thanks...... i hope it works
elbine69   +1y
Let us know how it works out
will keep yall updated..gona take sum pic's thursday and try to load em so yall can see my mazda
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 01:05. This post has been edited 1 times.
thanks for the info
