played out
played out
harris1
I know this subject has been brought up quite a bit i need to ask, which weber should i be buying.
my dawgs and 89 and i see that theirs an 32/36 or 34/36 and i dont know what the difference is and which one i should get!
so a lil help would be nice, thanks
oicu812's avatar
oicu812
I spent the little more and went with the 38, but I'm planning on more motor work. Lot of people on here talk about the 36's and I think Sosa has a 34/34. I think its kind of all up to what you are doing and what you want. If you got the 2.2 the 38 and a header along with advancing your timing should run amazing. I'm only running 2.0 with a header but builing one in my garage with a little bigger cam porting and polishing with a cold air intake. Might try a little bit of forced air, but I've been told these carb don't work under pressure. But I know there are plenty of threads on here bought all the different carbs.
91b2200(cody)'s avatar
91b2200(cody)
32/36 i would go with!
toddzda
The 32/36 carb is much easier to install, The 32/36 and 34/34 is suppose to be the same but with the 34 having a bigger opening i think. I had my 32/36 for 2 years now and loving it everytime i drive her!
kia swap
last post by Brody 12 mo
51
