what kind of fuel cell
lowridenmazda
Ok i want to put a fuel cell in my truck but i dont know what kind would be easiest to install or what fuel pump to run. Anybody got any suggestions?
h2omelon(nick)'s avatar
h2omelon(nick)
I'm running a RCI in my truck and have had them in several trucks.I used the stock fuel pump.The one I have now is only 7" tall and fits under the bed floor behind the axle.
badchicn (rick)'s avatar
badchicn (rick)
I have a custom built aluminum tank with a chevy electric fuel pump. Is yours Fuel Injected of carbed?
lowridenmazda
It's got a carb.
h2omelon(nick)
If it's carbed you can use the stock mechanical fuel pump.
devb22's avatar
devb22
I also have ran a lot of RCI fuel cell's
I would try to stick in the 10-15 gallon range, and the problem you will run into is your fuel gauge and the sending unit. The GM sending unit is most popular which has a range of 0-90ohm, if you were to hook this up to you fuel gauge it would read backwards. Full=Empty and vise-versa, that will be closest option without getting new gauges....
Try to get a fuel cell with a sump...And don't get anything over -8AN which is the equivalent to 1/2" line. Your carb will be swimming in fuel. You will most likely want to adapt it down to -6AN which is roughly 3/8" line...which is what most people have done...
Hope that helps you out...
kia swap
last post by Brody +1y
51
