Mazda Engine General \  Trying to pull 92 engine codes
views 830
replies 3
huskerdually   +1y
I hooked that green single wire connector to ground and the check engine light just stayed on, what am I doing wrong or is the ecm not communicating? It's a 92 b2600i.
midnightmike   +1y
sounds like you have no codes,
did you disconnect the battery anytime before you tried pulling the codes?
huskerdually   +1y
They don't flash a no codes code, if that makes any sense. Like gm vehicles will flash a code 12 to let you know there are no codes and it is working. Mine the light just stayed on, doesn't flash or anything. Just seemed odd.
dzminiz   +1y
mazdas won't give you a "no code" code.
If ya didn't get a code more than likely you have to switch the wires underneath the dash for the "required maintenance"
