Mazda Engine General \  brakes
brakes
views 553
replies 3
following 2
fitbmx180   +1y
ok, so i have a brake issue, i decided to put on a new brake booster as my brakes were squishy... so i put a new master cylinder on.. i put it on, but didnt bench bleed it.. so i bled a bit on the truck.. and didnt see any more air bubbles, so i stopped... i did it for 3 corners (passenger rear is connected to driver rear)... and my brakes are still squishy... do i need more bleeding or? any ideas?
mazdatweaker   +1y
Check for leaks. . .
Maybe you have a wheel cylinder that has failed inside a drum.
Or a front caliper seal is leaking.
Maybe a brake line has a hole in it. Or a split.
Maybe the original master cylinder or booster wasn't the issue, since you still have a "squishy" pedal.
fitbmx180   +1y
by squishy i mean soft, yea im going to bleed it more, then check for leaks.. wheel cylinders are fine..
fitbmx180   +1y
