Mazda Engine General \  possible? to run stock carb with out computer?
views 557
replies 5
farfegnugen   +1y
I have belive i have seen one or two photos of truck on here running stock carbs with or with out computer and vac lines
Post was last edited on Oct 01, 2009 11:10. This post has been edited 1 times.
toddluck   +1y
you can run a stock carb without pc but it runs like azz very rich
and you will wash the cylinders
farfegnugen   +1y
Well.... i have the vac lines capped and the computer plugged in still. i need to get the truck to just to start and run. for atleast 10-15 mins. so i can do a heat cycle and re tighten the head bolts
You have to have it floored to start it and the half way open it still misses and hisses.
toddluck   +1y
sounds like part of the prob is a major vacuume leak
elbine69   +1y
Yup def sounds like a vacuum leak
farfegnugen   +1y
So it should run either way..... so i need to find a Vacuum leak
