Mazda Engine General \  help asap
help asap
views 567
replies 6
mazda_speed87   +1y
i jus installed a weber carb and it ran good for a few days but then all of a sudden it wont idle at all now, at cruzing speeds it runs fine i jus dont get it i have replaced plugs, wires, fuel pump, coil, cap, and rotor botton i jus cant seem 2 figure it out please help!!!
shilaeli huggr (burdaddy)   +1y
take the carb off and all the plates. clean it up and use silicone to seal it up. mine did it. it was a vaccum leak between the plates.
toddluck   +1y
sounds liek a vacuume leak check hoses and then spray starting fluid around base of carb with truck running
then where intake meets the block and see if it runs when you are spraying
if so thats where your leak is
also check the carb bolts make sure they are tight
mazda_speed87   +1y
ok but did urs kinda miss up until about 2 grand??
toddluck   +1y
nope try the leak test if not could be choke adjustment
toddluck   +1y
if you didnt use loc tite or lock washers on the carb ill bet it came loose
paparoach1983   +1y
^^^yep
