Mazda Engine General \  temp gauge not up
temp gauge not up
views 9421
replies 12
following 6
maximus   +1y
can someone tell me where the switch/sender for the temp gauge is?
i can run all day and the temp gauge stays pegged down.
or might it be the gauge?
1lowb2200   +1y
There is actually two of them. One is on the lower driver side of the radiator. The other is a green plug on the intake manifold. Ususally the one on the radiator is the problem.
maximus   +1y
what are they called exactly?
"sending units" ?
or "sensors" ?
just need to know what to ask for @ parts store, never had this problem before.
how much $ are they?
hocbj23   +1y
If I remember my wiring, the sensor with the green plug on ur intake manifold goes to ur gauge.Before replacing, unplug and clean the connections with some spray electrical cleaner. U may find that they are dirty rather than non-functional.BJ
toddluck   +1y
on the t stat housing
the on the radiator goes to the carb
toddluck   +1y
to test the one on the tstat housing get a wire put it in the plug then ground it to metal if the guage pegs on hot the guage is good the sending unit is bad
mazdatweaker   +1y
Maximus. . .
It would help a lot if you would indicate whether your vehicle is fuel injected, or carb'ed.
On the carb'ed units, there is a rectangle shaped plug that provides a variable ground signal via the underside of the aluminum timing cover housing.
It is a single wire, located near the water outlet and bypass hoses on the thermostat.
Maybe the wire is disconnected.
Using an ohm-meter, the resistance of the sensor can be checked.
I would be careful about shorting the wire to ground. You can burn up the gauge doing that.
maximus   +1y
Thanks, man. It's carburated.
Sorry, thought 88's only came carbed?
I do have a hanging wire, disconnected. It's laying on top of the alternator, has a yellow connector.
Not sure where it goes. I was going to start by replacing the sensor that goes into the radiator, it's $8.99
toddluck   +1y
the one on the radiator will not help your guage its for the carb........
maximus   +1y
so the one with the green clip that goes into the carb/intake?
clean it first?
