Mazda Engine General \  CARB ISSUES
CARB ISSUES
views 589
replies 1
following 2
blackhulk   +1y
i bought another b2200...and my carb is messing up..its sputtering when u drive at a constand speed between 40-90kph..after 100km its ok but sometimes still does the samething...i tryed the carb cleaner were u rev the engine and apply the cleaner and then choke the engine to help flush the vaccum lines..did a tune up..plug wires and did some head work...still cant figure it out..its stanard by the way...i bought it for my gf and gonna pimp it out so we can criuse together..i cant afford a weber yet so im looking for my options to try it...thanks guys
mazdatweaker   +1y
You may not have carburetor issues in any way.
What have you done other than what you have posted?
Have you done a tune up?
"tune up" is a pretty ambiguous term.
Not trying to be rude, but the words mean different things to different people.
There is even a product you can buy to put into the gas tank that is called "tune up in a can."
What did the parts look like when you pulled them?
When / if you pulled the plugs did you look to see if the electrodes were in good shape or marginal?
Reading a plug is an art that will tell you a LOT of what is going on regarding fuel issues.
Individual plugs from each cylinder tell a detective story that you need as the one hunting for clues.
When I take out plugs, I keep them in cylinder order so I can look at them cylinder specific.
If you scramble them taking them out, you have just lost important facts.
Have you checked the spark plug wires for corrosion at the ends where they plug in and for correct resistance or bleedover?
Have you replaced the fuel filter, or inspected it for debris?
Did you replace the distributor cap and rotor?
Did you check the advance operation with a timing light?
