Lotsa White Smoke?
Lotsa White Smoke?
ozzitoolmetallicrue
Well. I had a ton of vacuum leaks on my intake manifold so i took it off and sealed off all the old unused vacuum ports after adding the Weber. It smoked very little before. Now after replacing the intake manifold. I have a ton of constant white smoke coming outta the tailpipe. I also got a new intake manifold gasket when i put the intake manifold back on. I don't have any coolant leaking out where the manifold connects to the block. So my thoughts are the gasket didn't seal on the interior like it should have and antifreeze is getting into the intake and is being burned in the combustion chamber. I wanted to get some more opinions before i took it into a mechanic. Thanks alot.
skrapinsask's avatar
skrapinsask
You for sure have coolant leaking into the cylinders. there has to be a coolant leak for lots of white smoke. Did you use a new gasket and clean the gasket area before reinstalling everything?
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
are you sure its white smoke? smell the smoke, does it smell sweet? are you loosing any coolant out of the radiator?
redo the manifold gasket its prolly leaking there
ozzitoolmetallicrue
Yep. I cleaned and wire brushed both the block flange and the manifold flange before i reinstalled the new gasket. And now that i think about it. I'm almost positive i put the damn gasket on backwards.
90-b22dawg [andrew]
wire wheel on a drill? thats the best way to clean.
ozzitoolmetallicrue
Yeah. I meant wire wheel. Not brush. But ya get the idea.
paparoach1983's avatar
paparoach1983
I GOTCHA haha
kia swap
last post by Brody +1y
51
