Mazda Engine General \  blown head gasket
blown head gasket
views 735
replies 2
iculookn42   +1y
I just found out my truck has a blown head gasket today. I plan on pulling the motor and doing a small rebuild. Does anyone have any suggestions on any up grades while I'm in there? I already have a webber and a header that is currently installed. It is an 89 2.2 bty.
tucked3rdgen26i   +1y
Main bearings/oil pump/rod bearings/gasket kitt full top to bottom/ water pump resurface head. and block to make sure you have a clean mateing surface... goodluck!... let me ... kno..
canucksfan1   +1y
if your pullin the engine, and your truck is standard, may be a good idea to swap out the clutch, and resurface the flywheel. (unless it was just done obviously)
Also you should change the timing belt.
